Lifter Question
Lifter Question
I have a question about my lifters. The other day I was installing a new pushrod because I had a bent one. I was also checking over my rockers and making sure they were loose at all. Well, I noticed that my #8 exhaust was kind of loose, I could move it so much that the roller tip could be moved off of the spring. I also noticed that I could push the pushrod down. Almost like I could push on the lifter play. Is this a normal thing to happen? I don't have much experience with this stuff, so I wasn't sure. I know the loose pushrod isn't normal, and I fixed that. I also found out I broke my rocker because it was so loose. But is it normal to be able to push down on the pushrod and move it down? Thanks for any help.
Re: Lifter Question
Did you yank the intake to do this or did you just yank the valve covers?
Bret
Re: Lifter Question
I just took the valve covers off. I did notice that I could do it to a few of the lifters. Example, if the rocker was loose(no tension from the spring) I could push on back part(where the pushrod pushes the rocker) and I could push down on the lifter/pushrod. You could feel a cushion of some sort. Is it possible I need new lifters now? I only have about 2,500 miles on these...I replaced them when I put a new cam in. Thanks.
oldschool
02-09-2016 09:21 PM
donot_4get
09-14-2002 08:03 AM
