lifter question???
lifter question???
when I'm adjusting the lash for my rockers do the lifters uncompress when I remove the load on them. do they naturally expand or is there some thing that needs to be done to make them uncompress. I'm just trying to re adjust my roller rockers thanks.
Do you know how to find 0 lash?
I will reach zero lash when there is no play with the push rod and the rocker right?? I usually spin the rod until I feel some a small amount of tension on the rod while spinning it, is that okay. doing this when nuber one cylinder is at top dead center. is that okay?
www.shbox.com
There's a full writeup there. I recommend pulling the pushrod up and down until there is not slack left instead of spinning it. If you go too far, you should leave that one for a while to let it expand back out until you go to adjust it again otherwise you'll put more preload than you want.
yeah I've got that websit bookmarked I really should make a donation cause it helped me out huge with my cam swap.I've just heard so many different ways to adjust rockers from 1/4 turn to full 360 I just have to ask. thanks for the info guys.
oldschool
02-09-2016 09:21 PM
donot_4get
09-14-2002 08:03 AM
