lifter tick/low rpm stumble
I am currently having issues with what I think is a ticking lifter, I plan on breaking it down and replacing all 16 but in the mean time i was wondering if anyone could suggest an oil additive that might help quiet the tick. Also I am experiencing a low rpm stumble any suggestions
Re: lifter tick/low rpm stumble
I have checked the headers i have no leaks im almost positive its a lifter had several certified technician say the same. How ever I do not have the o2 sensors hooked up I guess that could run it rich
Which O2 sensors are disconnected? Pre-cat, after-cat, or all? In the other thread you asked about using simms or tuning them out, which would apply to the after-cat sensors.
I have ordered some 02 sensors sims and i went to hook up the front O2 sensors in the mean time and realized the fronts are 4 pin flat so gotta pick another pair of sensors i guess? I'm having trouble locating the drivers side rear sensor plug any suggestions?
to answer your question all are disconnected i figured it would throw codes no matter, I have plug extensions and plan on hooking the front up this afternoon once i pick up some new sensors
C4m4roJoe
07-19-2015 10:59 PM
