which lifters to use?
Fixing to peice together my 383 LE3 setup and need to know whether or not to buy buy the Comp R lifters or will my stock rollers be up for the challenge. Anybody with a similar setup or the experience please help.
Re: which lifters to use?
My old 94 had the "common" valve train noise I read about here on this site and when I went to a comp cams roller shaft and matching springs, the noise worsened. I narrowed it down to the stock original lifters not being up to the task of the stiffer springs and caused them to bleed down more than before. Considering the amount of b.s. involved, I would just put in the new ones and avoid a possible headache.
