Light Weight Wheels
Light Weight Wheels
I am looking for a set of light weight wheels that wont cost me 650 a wheel. I like the FIKSE wheels but they are expensive. I would like to go with 17's in the front and 18x11+ in the rear, any suggestions?? Thanx for the imput!!!
If you want some light weight wheels, then I would go with some American Racing wheels or Weld draglites. Any 17 or 18 inch wheel is not going to be very light. If you are going for looks then don't worry about the weight of the rim. If they are for racing, then get the Weld's.
I am looking for both, style and weight, I found some FIKSE wheels that were the 17 , 18 inch set that I want, they are only 16-17 pounds. so you can get style and light weight!! The only negative is they are 650 each!!
BOTH Looks, and Performance minded. You won't find a better looking wheel on the market of this quality and weight.
You've just been given the golden pass. Use it wisely.
Bogart Racing Wheels
Ruben F.
Ruben F.
jj_burchiel
03-21-2015 12:51 AM
squarehead
01-15-2015 07:02 PM
