Limits for Head/Cam Combo
Generally, the most we try to run on a stock bottom end is an honest 420-440rwhp. SAE corrected anyhow
That's turning 6600-7000rpm as well, so like any stock shortblock under those conditions... yours may last, it may not. More often we've seen well maintained shortblocks that weren't subjected to anything outrageous last quite a awhile though .
That said, it's always fun to push it
Good luck!
Good luck!
So, what would go wrong, spin a bearing or loose rod. Is it the added RPM or the aggresive duration and lift that would hurt stock bottom end.
If going for 400RWHP and not revving more than 6500RPM-6800RPM, would the stock bottom last long.
09-11-2015 09:44 AM
