A little cam video of mine
Old 06-10-2008, 09:13 AM
  #16
JasonK94Z's Avatar
Are a lot of people lately putting cams in a stock motor without any problems? Seems like before people were doing this and the motor would be trashed a couple of weeks later.
How did your front cam bearing look?
JasonK94Z is offline
Old 06-10-2008, 01:41 PM
  #17
jer4251's Avatar
didnt really look at it. just put it aside and put the new one in
jer4251 is offline
Old 06-10-2008, 03:06 PM
  #18
hsyr's Avatar
How do you like how the 847 drives on the street? Does it need 4:10s? Would you go smaller next time? Power?
hsyr is offline
Old 06-10-2008, 03:36 PM
  #19
Pyrodawg's Avatar
i put a cc306 in my stock motor with ~144-145K miles and i have about 148or 149K now
Pyrodawg is offline
Old 06-10-2008, 04:32 PM
  #20
Z-RATED94's Avatar
When I did mine, the front one looked a little worn, and the stock motor only had 28k on it. I did replace the water pump with an electric one to take some load off that bearing. So far so good.
Z-RATED94 is offline
Old 06-10-2008, 04:51 PM
  #21
jer4251's Avatar
i like my 3.42's it pulls right to redline super quick. the 4.10's are suppose to keep the rpm up real high where the cam makes the most power. but with stock heads i make my power a little lower.
drives real good on the street, no bad surge or anything.
smaller next time??? not a chance
jer4251 is offline
Old 06-10-2008, 05:30 PM
  #22
jer4251's Avatar
idle is set at 900 rpm. and my rev limiter is set to 6900 rpm.
i run dump for exhaust. no catbacks here
jer4251 is offline
10-31-2016 11:09 AM
DirtyDaveW
03-15-2015 07:01 PM
NewsBot
02-26-2015 02:10 PM
NewsBot
01-29-2015 07:10 PM
Jon657
07-19-2002 07:51 PM
Quick Reply: A little cam video of mine
