little help please!!
Exhaust leak. Most likely your header gaskets are leaking or your header bolts need to be tightened down.
If tightening them down doesn't solve your problem replace the gaskets and use Stage 8 locking header bolts.
i put new mac headers and it's the same as it was with the manifoilds. same ticking noise. i got the stage 8 locking bolts i just have to put the retainers on it still but i tightened them up twice. i will go back through it to make sure there all tight but if thats not it what else could it be???
