Long Tubes with 1 inch drop will it work?
I have a 1994 z28 and iam going to be lowering it 1 inch with hotchkis springs and iam going to be getting headers also and looking at long tubes from jet hot so would i have a ground clearance problem with that? I think it should work i see guys using eibach 1.5 lowering springs with long tubes. I just have to take it easy of speed bumbs but i all ready do that. what else can you guys suggest so i dont hurt the headers or y pipe? iam going with a stainless works y pipe that is what ls1 speed suggested is that a good one if so how big 3 in????
You won't have a problem with longtubes if you do the FLP. I have almost 3 inches of drop and really have only hit the longtubes once and that was on a speedbump. I would still recommend always driving with caution, but don't sweat it. You will like the look of a lowered car and love the sound of your longtubes. Mike
Clearance?
Hey i was wondering about the same thing. But i want to go with the Hooker Long Tubes with a mufflex y-pipe and i also want to drop it about 1" with the eibach pro kit. Will this work? Will i rub everywhere? I don't want to have to worry about scrapping the bottom on every little bump. Does anyone have this setup or has pics? Thanks
01-05-2015 07:14 PM
07-04-2005 05:00 PM
