looking to get a throttle body
do you think this is a good deal?
http://cgi.ebay.com/ebaymotors/1993-...02027298QQrdZ1
or should i with a 58mm?
Re: looking to get a throttle body
At first glance it looks fine. Good price I guess. What are your mods?, because a throttle body that is too big for your current mods will infact hurt performance, just something to think about. Overall if you need a throttlebody I would try it
so far i've done K&N CAI ,shft kit 2400 stall i'll be doing gears (3.73) and cat back this month..
Your stock TB will be fine with the mods you have. You really don't need a aftermarket one until you're in the 400HP area. Then you might benifit from a 52mm TB. I still have a stock TB and I have pretty much every bolt-on and heads/cam.
I'd spend the money somewhere else. I'm not sure if a bigger TB really helps until you get some major horsepower. I'm not exactly sure my 58mm tb was worth the money.
I have seen dyno tests of some hp gains with 52 and 58 tbs even on mildly modded up cars. So it appears that they can help a bit .Sometimes theory and practice are two different things.
The car is already set up for a 52 but you need to bore out intake for a 58 or buy an adapter,seen those on eb. I just got a 52 but might go for a 58 when finish heads/cam/ and headers. Have zex wet kit also.
