Loose rocker arms
Loose rocker arms
Last year I had the joy of hearing a loud clicking sound from under the pass. side valve cover. Turned out a stock rocker got itself loose. Tightened it down, no problems since. Well, now its doing it on the driver's side and the same spot. I'll be pulling the valve cover Friday when I have my car again. Anyone else go through this ?
been there..... done that. i ended up have a bent valve so i had to get a valve job and all of that other bs. ended up costing me $2,300.00. i have heard that you could install some polylocks on them and they wont budge again. but check it out and ask around
good luck
-Mike
good luck
-Mike
