Loose sparkplugs
Loose sparkplugs
First off - I am a total bonehead...
I changed the sparkplugs on my 94 z28 a few wks ago, and I was so afraid about overtightening them that I guess I put them in with insufficient torque. I checked the plugs today, and it turns out that 4 out of the 8 were loose enough to come off by hand! (ie. they were turning as I was pulling the plug wires off the plugs!)
A week ago, I took my car to the drag strip for the first time and ran a best time of 14.2 @ 99.99 mph. The only mod was a hacked stock airbox and a deleted muffler. Do loose plugs make a big difference in how the car would have run if they were put on properly? Would I have atleast gotten over the 100mph mark if it were done right? Arghh..
Michael.
Michael.
Re: Loose sparkplugs
Michael.
Michael.
Ill have to run it again and see what happens. I wasnt too happy with the mph. The et's sucked b/c of my driving (2.4 60 ft). Car info:
94 z28 with 175k km's on the clock. M6 transmission. Stock tires, stock airfilter.. stock everything except for the two things I mentioned in my first post. I've been slowly trying to bring everything back to spec maintenance wise before investing in mods (ie. changing all the fluids, fuel filter, plugs/wires/coil).
Originally Posted by tanmanski
you might have lost a little (very little) power due to slight compression loss & lack of plug reach..............but not much, certainly no lasting effect. Just torque them all up & run the strip again & you'll have your answer. My guess is you're losing power somewhere else (the numbers look a bit slow)...but with no car info to go of in your (non existant) sig, who knows.
