loss of fuel pressure at high rpm
I have a miss at high rpm, 4000 and up. I thought it was the opti, but i hooked a fuel pressure gauge up last night and drove it, and I found that my fuel pressure was dropping to 35-38 at WOT, and sometimes would drop to zero for split seconds at a time. Any ideas?
If you do not plan on doing any internal upgrades to your car then you can get away with going with a Walbro 195 lph. If you plan on doing heads and cam then I would recommend going with a 255 lph intank pump. You may want to try and contact Jack at Racetronix.
