low coolant?
low coolant?
Hi guys, I just bought a 95 TA 6speed. The guy told me once and a while the coolant light goes on even though theres plenty of coolant, well he was right its on almost all the time. Is it just a sensor or what? Thanks in advance.
Re: low coolant?
Assuming you checked the radiator itself, not just the overflow tank it is probably the sensor or wiring. Sometimes a bad cap will let fluid get forced out over time and cause low fluid light (sensor working properly). Overflow tank will be around right level but radiator is half empty.
