Low coolant light.
Low coolant light.
My low coolant light came on the other day after driving about an hour and a half. I checked the radiator and overflow and everything looks good. Now it comes on afetr I drive a couple of minutes. If it sits overnight it will come on afer about 10 minutes of driving, but after its warmed up it comes on immediately when the car is started. I bought a new cap and that didnt do anything. The car is running fine and the temp is normal. Could it be the low coolant sensor in the radiator? I figured if that was it the ligth would always come on immediately and not only after its been warmed up. What you guys think? Could it have something to do with closed and open loop? Does the pcm not read the low coolant sensor before the car is at operating temps? That sensor sure looks like a pain to get to.
Re: Low coolant light.
10-31-2016 11:09 AM
