lower alternator bracket
just got my lower alternator bracket from SJM, machine polished one...and I must say that it got here in like 3 days and the bracket looks very nice. comes with all the hardware needed, belt, spacers, etc...
alternator looks really good sittin down low and it has really cleaned up the engine compartment! this has to be the coolest part (right next to my flameball light up shifter ****) on my car!!!
thanks SJM!
thanks SJM!
Re: lower alternator bracket
Is that something that can be done with an AC! instead of getting an ac delete pulley? I'm planning on yanking the ac this spring (dash controller died again) and would also like to stick the alt down low.
it actually depends on what your running....
this lower alt bracket that sjm has designed is for no use of no ac AND no power steering. there is a couple different style brackets you can buy for a non-ac car With power steering while still keeping the alternator below everything else.
i use to have an ac delete pulley if you would like that (its for sale...cheap) but that doesnt put the alternator in a different location.
i was going to email some pics out to a couple of poeple but if someone would like to shoot me their email so they could host it for me that would be great as well!
That's pretty nice but I just can't see spending that amount of money. If you have the tools you can modify the existing bracket and make two brackets approx $10 and get the same thing. Don't get me wrong it's a nice piece just a little to pricey for me.
Here is my modified bracket.
Lower Alt Bracket
Lower Alt Bracket
nice ken! i cam up with the same thing but i didnt want the tensioner on it and then I could get one of the bolts out because the tensioner was bad anyway...so i said screw it and bought the darn thing.
man...im diggin moms digi cam! im about to upload some more pics of the progress!
I had my doubts about using the tensioner until today. Just got my 355 together and had a private test session at the track. Had no problems at all, spinning the motor to 7K.
carguyshu
01-22-2017 11:19 AM
SMO Q
02-11-2015 07:13 AM
HectorM52
01-31-2015 07:29 PM
