LS1 brakes question (about brake line interchange)
I'm going to upgrade my LT1 to LS1 front brakes. What lines will work up front? Can I use LT1 hoses up front with LS1 hardware? Or can a set of stainless hoses for an LS1 fit both front and rear or can I use all of an LT1 kit? IOW, do I have to mix lines? Thanks.
I installed LS1 calipers with LS1 lines. They work fine, but you have to bend the hard line on your car to point "out" instead of "up". This is the results: http://z28.reanimator.org/pics/brakes_ls1_bracket.jpg
07-04-2005 05:00 PM
