ls1driveshaft
ls1driveshaft
what r the advantages of a LS1 aluminumn 3" drivehaft compared to teh LT1 2.5" steel drive shafts....someone on here is selling one and im interested in it...what would u pay for 1 with yoke included??
Re: ls1driveshaft
Re: ls1driveshaft
The only real advantage is to get rid of any vibration you might have now with the steel unit. It does cut down on a little rotational mass, but won't be noticeable as far as HP is concerned. It is also a little weaker than the steel one. I would say that if you are not having any problems, don't mess with it.
I bought mine out of a 2002 SS, it was in great shape. I tink I paid around 120 for it on ebay. It made a huge difference on my car, I had no more vibration on the freeway. When I got the driveshaft I replaced both u-joints and had it balanced. IMO it was worth it.
shoebox def know what he is talking about so i usually listen to him lol.....could my ds destroy my seals and not have any vibrations...like in other posts my pinion and trans shaft seal are leaking but i have no vibrations could it just be from rotting out...i mean the car is 7 years old?? just a thought.
Sure vibes can cause seal problems, but you would have likely felt it if it were a contributing issue.
On an vibrating driveshaft, it isnt the seal I'd be too worried about.. it's the tailshaft bearing inside. the seal is easy to replace, but the bearing isnt. If your driveshaft is bad enough, it will slowly destroy that bearing, which in turn will eat the seal up as well if it hasnt already been.
like isaid i have no vibrarions soo im really too sure about anyhting at the moment...but i do know my seals are leaking..any opinions
If you want an aluminum ds later on then you can still get one. Now that I think about it I'm not sure I'd buy the one you are talking about for 100 even. The guy doesn't even know what it is from exactly. What is he even doing with it? Also the lack of info in his profile would make me leery of him. I'm not saying he's trying to rip you off, I'm just saying that if I was looking at sending someone my money it would bother me greatly. I've seen aluminum driveshafts sell for less than that here plenty of times. I don't know what it's like in NY but where I'm at in NC, I could definitely buy one cheaper than that.
yeah im planning on doing everything in my sig and my seals plus much more when the weather breaks....dont really want to drive my car inthe snow lol and i had to store it outside this winter with a cover on it ....i was soooo pissed but hey winter her is very close to end (hopefully) soo ill updat u on my situation later....thanks guys
Originally posted by GREGG 97Z
My stock "vibeshaft" wrecked my rear at about 20k miles back in 1998, it used to vibrate pretty bad at anything over 80-90mph. I used to run it more often at those speeds or higher and didnt really know at the time what the vibration was coming from (a few years before I discovered this site). I was running it around 100 briefly one day and started to slow down and the rear was making a horrible grinding noise. The dealer said the pinion bearing had froze up and spun inside the rear housing, definitely caused by the driveshaft vibrations. Anyway at 20k miles I got a brand new rear for free and a nice new LS1 ds
