LT 1 questions
LT 1 questions
Hello all,
I am new here and my friend owns a 1996 Z28. We have a slight disagreement about what is really in the car and were hoping you guys could get it worked out. I searched high and low and could not find anything.
First he claims that there was a FIVE speed manual with the V-8 for the years 1993 to 1995 as an option (basicly the newer but not LS1 new body style).
Second, he claims that the 1996 Camaro had a hurst shifter option that gave a higher HP rating. Also claimes it moves him from a two bolt main to a four bolt main block? What is the true answer?
Would any of this be true?
Thanks in advance
Thanks in advance
Re: LT 1 questions
Originally posted by MonteCarlo31
Hello all,
Thanks in advance
Hello all,
Thanks in advance
5-speeds were only available for all V6 models; every V8 came with a 6-speed T56.
A shifter doesn't give you horsepower. The Hurst was an option on the WS6 and SS packages.
All f-body LT1 blocks were 2 bolt mains, while Corvette blocks were 4-bolt.
The only other way a 4-bolt block is in an F-body is in the limited production '97's, which had LT4 motors, but those are VERY rare (only ~100 of each were made), and some GM replacement LT1's were 4-bolt mains.
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
Hurin
12-13-2014 07:38 PM
