LT-1 removal
#16
Its simple to pull it out the top. Best way is to buy a happy hooker from tpis as stated before, it bolts to the intake mainfold where the fuel rail bolts down and has a hook on it to pull the engine with. Undo the wiring harness. drop the trans, take out the radiator, i dont have ac so im not sure if you would have to pull the condesor or whatever its called. Take off the accesory's and braket, and water pump. i can get mine out in about an hour and a half to two hours.
