LT-1 Valve covers with roller rockers?
pro mags are the only ones that dont fit. simply cut them.
scroll down to the bottom of the page, to see what it looks like.
http://www.golenengineservice.com/html/lt1_facts.html
i think that most should be fine, but if you want to save money and use the stockers, then thats how you do it. but I am pretty sure all aftermarkets should be fine. run a search, there are a lot of nice options out there. I just like the stockers because I know they will fit perfectly on the heads, and its cheap
Some covers still have some type of support. The proforms do not yet the are very rigid. Just be sure to torque them down as they say. And use the GM or blue FelPro rubber gaskets. Invest in a in/lb torque wrench.
The only thing you might have to do is squeeze the PVC/oil baffle w/ a pair of channel locks so they won`t touch the rockers. That and the alternator grinding, but this isn`t hard. It`s worth it w/ the Proforms.
i just put comp 1.6 pro mags on with poly locks...
the rr's hit the webbing ... so i took snips and cut the webbing off of the side or the inside, however you want to look at it...
and we caved in the area on the passenger side cover...(i think its under the PCV valve...
i would save your money and use the stock covers...
the height fit fine...
i guess i should read the whole thread before i post...
I have these valvecovers on my car.
http://cgi.ebay.com/ebaymotors/ALUMI...spagenameZWDVW
They still have the braces in them, so i notched them with my Plasma cutter. They're a great value you and virtually eliminated all my valve cover oil leaks. The price is hard to beat as well.
I feel the same way as you do. So, I just bought the Canton's off of Victory Racing on Friday morning. Great people to do deal with.
oldschool
02-09-2016 09:21 PM
