LT1 32 lb/hr Upgrade Injectors
Old 01-07-2005, 05:12 AM
  #31
Racetronix's Avatar
Re: LT1 32 lb/hr Upgrade Injectors
Originally Posted by 30696bird
Poor broke man here............I ordered 4 yesterday (37's) and will be ordering the other 4 here in a week or two!
Wow, that's kind of expensive to buy them that way.
Why not wait and buy them all at once to save on shipping?
Racetronix is offline
Old 01-07-2005, 05:33 AM
  #32
30696bird's Avatar
Had to break the payments in half so it looked better to the old lady. She don't know I need the other 4 yet, LOL.
30696bird is offline
Old 01-07-2005, 05:37 AM
  #33
Racetronix's Avatar
Sounds like risky business
Old 01-07-2005, 10:51 AM
  #34
NVRLATE's Avatar
How long is the sale going to run? I need some but I'm not sure what size to get. I still haven't made up my mind to get the LE2 or LE3 head/cam package.
NVRLATE is offline
Old 01-07-2005, 01:25 PM
  #35
Racetronix's Avatar
While quantities last.
Old 01-07-2005, 03:57 PM
  #36
GREGG 97Z's Avatar
LOL. I hear that, one of my favorite moves too.
GREGG 97Z is offline
Old 01-14-2005, 10:28 PM
  #37
blue's Avatar
I looked at the website and noticed that the 42#s are the same price as the 37#s. I don't expect I would ever need the 42's unless I transformed my car into a top fuel dragster, but would there be any advantage in 42's for a 380-430 rwhp car?
blue is offline
Old 01-14-2005, 11:48 PM
  #38
Racetronix's Avatar
That depends on your motors BSFC and max RPM. 42's are not oversized and are just as manageable as 37's.
Old 02-01-2005, 08:30 AM
  #39
#7's Avatar
When you say 37lb. injector for 450hp,is that flywheel or rear wheel? What injector for 420-30fwhp/350-60rwhp?
T.
#7 is offline
Old 02-01-2005, 09:08 AM
  #40
Racetronix's Avatar
T.
RC has a good injector calculator on their web page here:
http://www.rceng.com/technical.htm
Factor in a 15-20% drivetrain loss, and max DC of 0.80
Old 02-03-2005, 08:14 AM
  #41
#7's Avatar
When I subtract 15% drivetrain loss before from 420fwhp(read crank) gives me 357 rwhp and the calc. says 28lb. injectors.
bsfc .5
duty .8
pressure 43.5psi
The calc says to add in crank hp or BHP? Isnt that the actual motor hp,which in my case 420crank hp.
Then the calc. gives me 33lb injectors
Which is right?
Unless I am completely clueless it seems the calculator wants the crank/bhp with NO drivetrain loss subtracted from the crank hp before for the calculation??
Also, Is there any things one can do to a motor that can change the BSFC requirments?
I used .50 The motor has ported/polished heads slightly higher compression??
Thanks,
T.
#7 is offline
Old 02-03-2005, 08:22 AM
  #42
Racetronix's Avatar
bsfc .5
duty .8
pressure 43.5psi
Which is right?
Thanks,
T.
The calculator is for FWHP.
The FWHP # does not factor in parasitic losses on the motor for such things as water pump, alternator etc. in order to net the FWHP #.
Other things which have to be factored in are the AE / async fueling as well as temperature trims for coolant and air which can add as much as 15-20% to compensate / protect a heat soaked or ultra cold motor.
Wetting of the intake tract nets some fuel loss. Heated / aerated fuel.
Fuel pressure dips etc.
Old 02-05-2005, 09:04 AM
  #43
96camaroz28lt4's Avatar
Nice! But better wait till I get my stock heads/intake/throttle body ported before I put bigger ones.
96camaroz28lt4 is offline
Old 02-09-2005, 09:25 AM
  #44
30696bird's Avatar
Risky business????? Sure, but it paid off, I ordered the other 4 last saturday or sunday.
Old 02-14-2005, 11:03 AM
  #45
Racetronix's Avatar
ttt
Quick Reply: LT1 32 lb/hr Upgrade Injectors
