LT1 32 lb/hr Upgrade Injectors
#46
Re: LT1 32 lb/hr Upgrade Injectors
Hey Racetronix,
quick question...I bought a set of the 32# injectors and on one side they have "24" printed on them...can you confirm that the 32#'s are like that? I just want to make sure if I got the wrong ones I can take care of it because I don't exect to start my engine for another month or so.
They also have the #'s D1720BA and 1752 printed on them.
Thanks!
Thanks!
#47
Originally Posted by RX
Hey Racetronix,
Quote "Part Number Delphi D17208A (Lucas old 5207009, Lucas New 621020)"
#49
I have some bosch 32's and I was curious if you kept that plastic type piece on the bottom of the injector or is it meant to come off? A couple of mine cracked and broke off. They kind of look like protectors, but they are form fitted to the injector itself, kinda like a glove fit.
#50
#52
Hi Racetronix I got an important question for you;
I built a 383ci LT4 with 210cc AFR Competition Heads.. I use your complete fuel system.. I want to ask you about injectors. People said to me that I should use 30lb injectors. But now I read this thread ,and I'm totally #### ! because I have 550hp at flywheel,so is it not enough "lb" for injectors??? Its a daily car,not a race car,nor a drag car..
#53
#55
Originally Posted by Racetronix
You will need 42# minimum to maintain 80% injector DC on a N/A 550FWHP motor.
thanks
#56
Minimum 42#??????? What are you talking about? There are a big size difference between 30# and 42# !! I repeat, this is a highly modified street car,not a race car. Do you approve your reply? Beacuse if you do I will change that..
thanks
thanks
To make 550 N/A @ 80% DC @ 43.5PSI that is what you will require.
Do the math!
The other question is what is the problem with 42's. Heck that is a small injector. TR's and imports run 60's with factory type mileage and drivability. Its all in the tune! Why do so many V8 owners subscribe to the just enough or not enough theory. This is not like picking a carb jet.
You can use this vendor's page if you wish: http://www.rceng.com/technical.htm
#57
The application is irrelevant (street /track). The FWHP is!.
Do the math!
Do the math!
#58
That was no offense man I'm very confused because lots of 383ci LT4 engine package 30lb injectors are used.. One more question, (you have a lot knowledge about this) what should be the fuel pressure for 550 bhp??
#60
43.5PSI base unless you need more in which case you will have to recalculate your injector constant when programming your ECM/PCM.
Kind regards..
