LT1 4 bolt main stud/bolts
Does anyone know the part number for ARP bolt/studs for LT1 4 bolt mains with windage tray? Im having a really hard time finding a kit that will work.
Also does anyone know if I can use a corvette LT1 oilpan on a Fbody camaro? Will there be any fitment issues with the K member?
I tried the pan the other way - a 'F' body pan on a Vette - baffle wouldn't clear the oil pump. So I stored the 'F' body pan in the garage and bought a stock 'Y' pan. Hope you have better luck.
Have you done a search on SummitRacing and JEGS for those ARPs?
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Jake
That's for 2 bolt apps. OP is asking for 4 bolt mains. I didn't see any 4 bolt LT1 mains listed in the catalog either. Have the never offered main bolts/studs for LT1 motors or are the just restarting production? I thought I had ARP main fasteners in my old 4 bolt LT4 build but maybe the years have faded my memory. I don't see why you couldn't get the 2 bolt kit and order the outer studs from another kit that match to make it work. Good luck,
Larry
Larry
Please call ARP directly. Their website says that works for Chev small blocks EXCEPT LT1 and LT4. I'd hate to see you spend your money without making sure they're correct...
Lt1son
12-31-2014 01:35 PM
