LT1 Alternator Relocation Bracket TESTING
#31
Hrmm.....doesn't look like I could use that bracket with my S-Trim right there.
Besides, IMO it doesn't make much sense to relocate the alternator yet put a pulley in the same spot. I would much rather just not have anything there at all and be able to cut the upper part of the accessory bracket off.
Especially if I was paying 200 bucks for it.........
#33
Originally posted by 94TA_LT1
any update? belt size?thanks man
#35
most auto parts stores will have a book from dayco that has the demensios of the pulleys out there,
Q, if you can measure the width, diameter, number of grooves and the id and od of the bearing, I should be able to get a part number
#37
The belt size for all stock pulleys is a Napa 060770.
#40
Originally posted by Grover
The only way you're going to be able to not have a pulley up there is to totally change the power steering pump system to turn the opposite direction it does now. Maybe that will just mean putting the one from a Corvette on there or it may mean designing and building a pump of your own, or it may mean eliminating the power steering altogether.
#41
Originally posted by allshow
The idler pulley can be ordered at NAPA. Part number 38008 I highly doubt that the pulley and/or bearing will fail anytime soon. It is actually meant to be an idler pulley for some other vehicle.
#43
I have been driving it for about a week. The only slippage I get is a slight squeel at a WOT blast from a dead stop. Otherwise all is fine. No problems whatso ever. Feel free to ask other questions if you are intersted. I will do my best to answer them.
Q
Q
