LT1 Block
Re: LT1 Block
does it still have the opti on it? if it does the 93-94 will no be vented where as the 95-97 will be vented and have vaccume lines running to it. i also thing the 95-97's didnt come with oil coolers .
Re: LT1 Block
No... you said:
The 4-bolt block was not unique to the LT4, it was used in all Corvettes from 1992 to 1996, including the Corvette LT4's that were built only in 1996.
There is a shortened form of the original car's VIN stamped at the back of the block. That might give you insight into the year of the car it was originally installed in. Shoebox has a photo of where the VIN derivative is located.
....or 4-bolt main, which came with the LT4, IIRC
