Lt1 Cam
Lt1 Cam
Need help im putting together a 1995 camaro and im trying to find a cam that best fits my car and what im doing with it. The car is going to see the 1/4 mile drag strip more than anything, heres what i got 1995 camaro 3400lbs dry,th350 with trans brake,3.73 gear with 28 tire, the engine is a 383 11.7cr with srp forged pistons and egale 4340 crank and H beam rods. lt1 heads ported by Elliott portworks,the heads flow 287-201@600 and peaked 290-@630. aslo spraying a 200-250 shot of nitrous.My pcm limits my rpm to a max of 7200rpms,and my valve springs right now are only good for a 600 lift but i am willing to change them. i want a Hydraulic Roller cam i was running the cc306 does anyone know where i can have a custom grind done or have any ideas of what cam fits my car best? thanks KYLE.
There are eleventy billion cam threads, you might want to read some of them. Or, either do as suggested and go with one of the grinds Bret specced out for Lloyd Elliot or get a "custom" (probably not needed for your application).
Rich
Rich
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
