LT1 "cam only" dyno record
#121
#122
hey *****... bring that bitch down to louisiana and race frank and see what happens....
and yea a "cam only" car is a car with full bolt on's (lifters RR's etc) and a cam and UNTOUCHED HEADS! that is what a cam only car consists of. if u throw nitrous, a blower/turbo in the mix it isnt cam only nemore and if u touch the heads watsoever, it is not a "cam only car" nemore.
#124
352/364 SAE here with the XE224/236. Car still has shorties, stock water pump, and full catback with muffler and no cutout. Heads never been off.
I can't remember the STD #'s but from what I've seen those are usually a bit higher than the SAE #'s.
#126
...I'm against FULL tuning on the dyno. So, this is no dyno queen. Just trying to break the cam only LT1 record, for the hell of it. Why not? It will just help bring more respect to the LT1 engine. Bad enough that everyone skips them to build gen III stuff. There is more potential in a stock LT1 intake than a stock LS1 intake (not ls6), IMO. The LT heads can be made to do most anything.
I already told you the next dyno session will use a SAE correction factor. What more do you want, blood?
#127
Did I say the record is for the highest dyno numbers in the correction factor of my choosing (with track # that will make everyone happy)?
#128
If you would have gone to PRI last weekend you would realize why, the LSX aftermarket is growing fast as hell, while all LTX guys have to look at is a worthless edelbrock intake manifold.
No one uses a stock LS1 intake, they all use the fast or LS6. And most cam only LS1's make more power than most H/C LT1's. And if you were at the PRI show last weekend you would realize the LTX aftermarket is a ****ing joke compared to the LSX aftermarket. Hell most big companies were displaying LSX heads and blocks.
Track #'s.
Track #'s.
#129
Track #'s.
Track #'s.
Going for the LT1 "cam only" dyno record is just that, a DYNO record. Track times have nothing to do with it. Let's get real though. ANY car making over 370hp at the rear wheels is no slouch.
BTW, stock LT1 intakes are just that good. They can be made to do just about anything.
#131
#132
#135
