LT1 Cam Question
LT1 Cam Question
i just bought a Cam for my Car.. it is a .525 lift, and i was wondering what head setup i would want for best performance...maybe a 2.02 1.60? what size injectors will i need? and also, who could i get to Flash my ECU? it is a 1993 Z, and what for increase on power will i see?
Re: LT1 Cam Question
You might want to do a head and cam package to increase your power. Search for LE1, LE2 and LE3 and you'll get plenty of info.
Good luck.
ok, i will have the specs on here soon (i have to find the Grind Paper)...anyways, i have a local machine shop that is going to port the heads and do a valve job...do you think that they would know what for head specs i would need to make this cam run good? def. replacing Lifters, Springs, Pushrods, etc. but the Duration is .219 intake .219 exh. - 112 Lash, thats all i can remember...hopefully i can make this cam run good...if i were to call Lloyd, do u think he could help me figure out what port #'s i should use? any help would be nice, for i dont know to much about Top end when it comes to #'s...thanks
No, I don't think the average local machine shop would know what to do unless they are a sucessful race shop which ports their own heads. Because porting is so special, many engine builders have their porting done by an expert.
If you mean to ask Lloyd what should be done to your heads by someone other than himself, you are expecting a lot. Head porters make their living by selling their handiwork. Giving away the info doesn't do a lot for the bottom line. The specs on the cams Lloyd sells with his heads are another item that isn't given away, and has generated considerable discussion.
If you "dont know to much about Top end when it comes to #'s", you are wise to admit that...many folks won't admit to themselves that they don't know. You'll be way ahead on power if you use your heads as cores for a head and cam package instead of trying to DIY. Hey, sell the cam on ebay. You might make a profit!
If I sound like an ad for Lloyd, it's mainly because his stuff works. There are others who do similar stuff, but I am more familiar with his work. Look around.
My $.02
oldschool
02-09-2016 09:21 PM
Brandon Wittmer
12-20-2014 09:51 PM
