lt1 choppin and spittin
whats up guys, ive got a 94 formula and every once in awhile it will chop out real bad when i accelerate and wont get up to speed. it seems to do it when ive been driving for awhile like maybe when it gets hot? what do u guys think
Might try replacing the fuel filter. Its cheap and if it hasn't been done for a while it's a good time to do it. Probably something starting to go like to opti or even the fuel pump. How many miles and whats been done to it?
I had similar problems. Cleaned the maf and throttle body. Smoothed it out. At the same time I replaced the fuel filter and coil wire. hard to tell what actually solved it, but only cost $30 to fix.
I seems to me that the main factor with yours is heat. replacing the coil possibly could help. Search problems with coil.
Jim
Jim
oldschool
02-09-2016 09:21 PM
