LT1 Dyno Results
Old 03-10-2007, 08:20 PM
95Z28ConvtM6's Avatar
LT1 Dyno Results - with graph
Just got my car dyno tuned by Bryan Herter. Here is what we ended up with:
387 RWHP / 366 RWTQ in FULL Emissions trim, including Cats, EGR and AIR. This final pull was done with a warm motor.
HP peaked at 6150rpm and the TQ peaked between 4500 and 5000. The TQ curve was VERY flat making over 350 lb-ft from 2000rpm through 5800rpm. Peak HP didn't start falling off until 6400rpm. the car is extremely responsive and makes power from 1500 through redline!!!
-LE2 Heads
-LE1 Emissions Cam. Duration is in the low-mid 220s with a wide LSA.
-355 LT1 shortblock by D&F Performance in Williamstown, NJ
-1.6 Rockers
-58mm TB
-Stock intake with TB holes opend up to match the 58mm TB
-30 lb Ford injectors
-Jet Hot LTs with emissions fittings
-Mufflex 3.5" exhaust and y-pipe with 3" cats (not hollowed out)
-6M with 4:10s
I just like to give a special thanks to Lloyd Elliot for flat-out nailing the combo, to Dave at D&F Performance for doing a superb job with the SB and engine assembly and to Bryan Herter for his tuning abilities. We picked up almost 20hp on the dyno. Well Done!!
95Z28ConvtM6 is offline
Old 03-10-2007, 08:35 PM
Moderator
Javier97Z28's Avatar
Nice job! Great #'s for a total emissions setup w/ cats and all. Plan on taking it to the track?
Javier97Z28 is offline
Old 03-10-2007, 09:35 PM
89TramsAmGTA's Avatar
Nice numbers. Looks like a lot of power under the curve.
89TramsAmGTA is offline
Old 03-10-2007, 09:41 PM
speed_demon24's Avatar
Nice #'s, any chance of you posting up the dyno graph?
speed_demon24 is offline
Old 03-10-2007, 11:36 PM
Z95m6's Avatar
Now add an electric waterpump and a ported intake and you should be at 400+rwhp.
Z95m6 is offline
Old 03-11-2007, 12:15 AM
Feenix's Avatar
Pretty impressive especially considering the emissions factor.
Feenix is offline
Old 03-11-2007, 08:25 AM
Z-RATED94's Avatar
Nice numbers and emissions friendly, sweet. And being an M6, I'll bet it's a gas to drive.
Z-RATED94 is offline
Old 03-11-2007, 10:33 AM
Moderator
Projectz28's Avatar
Nice numbers! Where did he dyno tune the car at? Your just across the street from me too Bryan is going to tune my car wen I get it back together but its taking a bit longer than I had expected. Bryan is top notch!
Where is D&F? Never heard of them before. What's in the short block?
Projectz28 is offline
Old 03-11-2007, 11:48 AM
2000GTP's Avatar
Nice numbers, nice to see good results from a emissions friendly setup.
2000GTP is offline
Old 03-12-2007, 10:16 AM
I wanted setup that was driveable and responsive. Yes, it is a blast to drive!
I had it dyno'd at JD's in Huntington Valley. Bryan rents the shop dyno for tuning.
D&F is in Williamstown, NJ. They've been around for at least 20 years. They were amoung the 3 highly recommended SB chevy builders in the Philly area. No complaints! The short block is balanced, has forged pistons, it's squared, decked, etc. It has the stock crank and rods.
I hope to get to Atco within a few weeks.
I'll try to get the dyno sheet up shortly.
Old 03-12-2007, 11:00 AM
SStrokerAce's Avatar
Lloyd told me about that one, good numbers!
Bret
SStrokerAce is offline
Old 03-12-2007, 11:09 AM
RealQuick's Avatar
Nice!!
RealQuick is offline
Old 03-12-2007, 11:48 AM
CamaroRacing12's Avatar
god all these nearly 400+rwhp #'s are giving me the itch for more power!
CamaroRacing12 is offline
Old 03-12-2007, 12:08 PM
user 647483's Avatar
Hell yeah!
user 647483 is offline
Old 03-12-2007, 01:14 PM
Moderator
Projectz28's Avatar
never heard of them before. I was curious because you said "forged 355". I assumed you meant crank and rods were forged also.
Yeah I've been to JD's before. Bryan will probably tune my car there also.
Quick Reply: LT1 Dyno Results
