LT1 fresh rebuild backfiring help!
#32
After the previous testing session I pulled the plugs and found #7 fouled out covered in very dark soot, #5 clean and pristine as the day it was put in. All the others looked about the same, used but not nasty like #7. These were new plugs put in for and about 30 minutes of runtime. I'll try and take a photo of the plugs this evening.
I'd also thought of the burnt wire because I think the right-side O2 is pretty close to the header BUT that is the opposite side from the bad #7 and weird #5 plug???
#33
Since i have a 95 Z i've never messed with the early opti's but i know its very possible to install them just a few teeth off. This would throw off your timing and could easily cause "popping/backfiring".
#35
I had the same problem you are having in November when I rebuilt the LT1 in my 1994 Z28. What happened was, even though I followed the procedure in the haynes manual for adjusting the tightness of the rockers, I guess because of the new cam, they were too tight. I took the valve covers off, backed the nuts off 1/4 to 1/2 turn. After that the car ran perfect! It's worth giving it a try and only takes about 15 minutes to do. I hope it works for you.
#37
No. All a scan will tell you is what value the PCM is picking off the timing tables. There is no way to know from a scan if the Opti is indexed correctly to the cam sprocket.
I'll take a look at your DataMaster file.
#38
OK, here is a photo of my plugs... not sure how well it will show up but these were brand new when I installed them. #5 is really cleaner than it looks in the photo, #7 is black as night, the rest are fairly uniform. There is about 30 minutes of run time on these.
#39
My plugs looked like that (certain cylinders running richer than others), and it was due to a bad coil. You could try this test:
http://shbox.com/1/coil_testing.jpg
I just swapped coils out (using someone else's) and found the culprit.
#44
Fixed it.
Previous owner had #6 and #8 crossed
Plugs gapped at .060
and a burnt #5 he tried to cover with tape
Runs like a champ with the exception of the header collector leak causing a pop in the system, going with Longtubes real soon and a better catback....... this one sounds like chit
10-31-2016 11:09 AM
Sergio
01-27-2016 04:27 PM
Oncomingstorm22
01-22-2015 07:15 PM
