Lt1 fuel problem. Please help!
Old 02-26-2012 | 03:33 PM
Jordan Radesi's Avatar
Hey guys really need some help. When trying to start my car I don't thi the injectors a spraying fuel into the cylinders. I did all the test for the fuel system and only thing I could find is when I check voltage on the injector plug it has voltage going to it all the time when I think it only should have power going to it when it sprays? What u guys think it is or what else can I check. It's getting spark and timing is good so I'm stumped. Thanks!
Old 02-26-2012 | 03:41 PM
Re: Lt1 fuel problem. Please help!
What year is your car? Not all years of the LT1 engine are the same. Add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. That helps us help you.
You should have 12V power to the pink wire in each injector harness connector at all times when the key is on. The PCM supplies a ground to fire the injector. If either the injector, the power supply to the pink wires or the PCM ground circuit is faulty, it will set a code for the injectors in the PCM. I'd tell you the code, but don't know the year, so I can't.
Have you scanned it for codes? Have you checked the fuel pressure? For example, if there is a problem with the low resolution pulse signal from the optical cam position sensor in the Optispark distributor, the PCM will set a code for loss of the signal and shut down the fuel system, but does not turn on the SES light for that code.
Old 02-26-2012 | 03:47 PM
It's a 95 six speed lt 1. Check engine light isn't on but never had the dash apart so I don't even know if there is a bulb in there in the first place. I know I have fuel going to the fuel rail but not sure what pressure it has.
Old 02-26-2012 | 04:00 PM
RamAir95TA's Avatar
Whether the bulb is in there or not it will still tell you if there are any codes present. Not all codes set the SES light either, so it's worthwhile to have it scanned.
You'll also need to pick up a fuel pressure test gauge. They are fairly inexpensive (<$40) and are an invaluable tool for any LT1 owner.
Old 02-26-2012 | 04:14 PM
Ok the light is on and tried to get a code from it but all the light does is stay on and doesn't flash to give me codes. Must not have the paper clip in right?
You said:
I did all the test for the fuel system.....
...... but you didn't check the fuel pressure? What "test" did you actually do?
Old 02-26-2012 | 04:16 PM
I checked and made sure I had fuel in the fuel rail by pressing down on the valve where u put the guage. Fuel sprayed out very good so I would think the pressure is good
Old 02-26-2012 | 04:41 PM
So you were able to determine from that test that the fuel pressure was meeting the minimum requirement of 41psi?
If you don't want to check the pressure, don't bother. Maybe you'll figure it out without testing it.
Old 02-26-2012 | 04:46 PM
So your saying even if I have fuel in the rail if it's not the right pressure the injectors won't spray at all. Not trying to do it the easy way just won't be able to get a guage right away.
Old 02-26-2012 | 05:35 PM
Just need to know what would make the injectors not to spray. Thanks for the help guys
Old 02-26-2012 | 06:50 PM
MyShibbyZ28's Avatar
What Injuneer is saying is you need to do this the right way. There is no "easy" or "quick" way.
You are stuck on this whole notion that the injectors are not opening. I highly doubt that, and the injectors will still open if there is absolutely no fuel in the rail. I have never heard of an injector (and what you are hinting at, all 8 of them) not opening.
Also you cannot jump your 95 with a paper clip to flash the codes on the SES light. The last year you could do that I believe was 93. On 94 and 95 years you need an OBD1 scanner, or a cable and use FreeScan.
Lastly, you have not said once what the actual symptom was of your starting issues. All you said is during starting you think the injectors are not getting fuel, this explains nothing.
What exactly is the car doing/not doing, and what are the main problems?
Old 02-26-2012 | 07:02 PM
After taking the motor apart to install new timing chain it won't start. I have good compression and spark from the coil and at the spark plugs. Pretty sure the timing is on after doing it plenty of times. So my problem I have is no fuel is going into the cylinders.
Old 02-26-2012 | 08:09 PM
No, I didn't say that.
Since it appears you are more intent on engaging in a debate over semantics than you are in fixing you car, I'll bow out.
Good luck.
Old 02-26-2012 | 08:23 PM
I'm getting a pressure guage tomorrow. Didn't mean to **** you off man jeez. Just new to this forum thing so it's kinda hard to explain what the car is doing. Sorry again
Old 02-26-2012 | 08:37 PM
blown94's Avatar
Id like to know if he figured the compression was good in the same manner he guessed the fuel pressure was good?
Listen, if u dont have a noid light set, go buy a cheap test light and clamp a paperclip to one end an insert it into an injector plug and prod the other terminal and have someone crank the damn car. If it flashes then you have injector pulse. Even if u do have pulse, im willing to bet you did not insert the opti correctly and the pin is the proper place, thereby making your spark timing incorrect and causing your no start.
The cam dowel drives the optispark and needs to be in the correct spot and ive heard of people not lining it up properly before.
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
nophix
11-30-2014 10:26 PM
07-04-2005 05:00 PM
smacz28
08-06-2002 01:51 PM
Quick Reply: Lt1 fuel problem. Please help!
