LT1 header questions
Old 10-02-2014 | 10:24 PM
Savage_Z28's Avatar
Hello all. I have a couple of question and I would like to get them cleared up before I buy headers. I wanna go with long tubes and preferably stainless. Is there still any affordable stainless long tubes with A.I.R and EGR hookups? If I decide to get headers with the hook ups and then decide to get rid of the A.I.R and EGR system is there a way to block off the connections on the headers? I know about the block off plates for the engine but what about the headers themselves? Thanks again guys for any input!
Old 10-03-2014 | 07:15 AM
Re: LT1 header questions
The PaceSetters are available with AIR/EGR. Mild steel, but available with cera-metallic coating.
Pacesetter Long Tube LT1 Headers, 96-97 w/Emissions
Interesting that they say "emissions" but I don't see any evidence in the photo.
If you buy a 3-piece EGR blockoff plate set, one of the plates is for the connection on the header #8 primary. AIR can be blocked but the specifics will be determined by what type of connection they provide on the headers... internal or external threads, requiring a plug or a cap. Not all header AIR connections match factory. Some require adapters.
Old 10-03-2014 | 08:38 AM
timnfxr's Avatar
Here's a better picture from Summit. It looks like they have the A.I.R. ports and the EGR exhaust tube.
Pacesetter Long Tube Headers
Old 10-03-2014 | 08:43 AM
FredM's Avatar
Make sure the emissions tube on the top of the header match the emissions fitting on the car. Good luck, let us know how it turns out.
Old 10-03-2014 | 01:09 PM
Savage_Z28's Avatar
Ok thanks guys! I'll be getting a pair when I get the money together!
Old 10-03-2014 | 10:41 PM
Not Dave's Avatar
Yeah stainless you'll be paying more. Stainless Works has a good set, so does Kooks.
I used to think Pace Setter's were cheap but that was several years ago. Now that I have a Z28 I'm seeing a lot of guys using them. Searching on the net I see you can get them from plain to coated. When I do go LT headers I won't rule them out by any means.
Old 10-03-2014 | 11:09 PM
Savage_Z28's Avatar
Yeah they are definitely becoming popular. I need to figure out if you can still pass emissions with the egr and a.i.r codes tuned out.
cmdeshon
12-27-2014 10:06 AM
SpeedJunkee
12-09-2014 10:17 PM
07-04-2005 05:00 PM
Quick Reply: LT1 header questions
