LT1 into 1959 Chevy
LT1 into 1959 Chevy
My buddy just bought a 59 Chevy Impala that needs a new motor. We were looking to put in an LT1 from an old B-Body.....we want to keep the car carbed to keep it simple. We know we need the following....
GMPP LT1 carb manifold, Low psi fuel pump, distributor "HEI?"
What else is needed?
obviously there is no timing marks so how do you set timing?
Thanks in advance
Thanks in advance
Re: LT1 into 1959 Chevy
If EFI is all you want, then the L98 or other traditional small block is a better choice. The LT1's strength is in the reverse cooling...allows you to run higher compression ratio and more advanced timing on pump gas. Even carburated, these advantages are still available.....
Don't most aftermarket dampers have the crank degrees already marked on them? I would think that,and an adjustable timing pointer would be all you need. That and a degree wheel and dial indicator to find TDC.....
It looks like we will also need the GMPP front cover plug....it also has a timing mark on it....do we align that mark to the mark on the balancer when using the timing light? P/N 12367600
Don't trust any factory marks on the stock damper (its not a "balancer"). The stock damper is not keyed to the crank, so the mark is not reliable. For your application, I would buy a keyed hub for the stock damper (the crank already has a keyway), so that you can be certain the damper has not moved.
basically need to know what parts im gonna need to put this thing together.. also are the motor mounts gonna line up with the frame? have a pos 305 in her now with bad rod knock..
Kind of like the lb./in. vers in./lb. thing!
Well, not quite. Inch-pounds and pounds-inch are interchangeable because they are the same. The device on the crank is a harmonic damper as it damps the twisting force harmonics that could beat the crankshaft to bits if left unchecked. These forces woul still be there even if the rotating assembly were perfectly balanced without the damper present.
People use the terms interchangeably but that doesn't mean it's correct to do so....
F'n1996Z28SS
08-23-2023 11:19 PM
CARiD
01-14-2015 04:00 AM
NewsBot
01-11-2015 06:10 PM
formula79
18
07-01-2002 02:39 PM
