LT1 to LT4 Cam question
I'm replacing my LT1 with LT4 intake and AFR LT4 Heads. I was wondering how well the LT4 Hot Cam does compared to other Cams that could be used. I'm not looking for anthing outrageous as would be possible with this setup. Just something for strong mid range power. Not looking for power above 6,000rpm. Also will be installing a Moser 12 Bolt with .373 Spool if that helps with the suggestions.
Thank you!
Thank you!
Re: LT1 to LT4 Cam question
I have had the LT-4 hot cam since 1998. It makes good power. I dynoed at 357 rwhp and 360 torque. My heads are only a stage 1 port job. The cam is very streetable. It sounds like it will fit what you want. There are other cams out there that have the same driving manners as the hot cam and make more power. Others can give more advise on these cams. I just swapped in a 224/235 .525/.536 comp cam. 114 lobe sep.
ZMAN
ZMAN
Another question. Can I eliminate the egr and air with that cam and the car still run like it has it? Like program the computer to the LT4 specs or something like that.
oldschool
02-09-2016 09:21 PM
Brandon Wittmer
12-20-2014 09:51 PM
