LT1 to LT4 Conversion Question?
#16
Re: LT1 to LT4 Conversion Question?
Originally Posted by steve9899
The LT4 hotcam can be used in any LT1/LT4. Dowel pin is adjustable.
#17
Originally Posted by TABAHR
What about the LT4 timing set? With that work with a non-vented opti too?
You might want to try searching as all this is FAQ.
#18
OK So I think I am going to go with the LE1 kit instead of the LT4. I will get that Longtubes, 52mm Throttle Body,CAI, MSD Ignition and the ECM custom Programmed. How Much Hp flywheel and Rear Wheel do you think I will run. Will it be more than the Lt4 kit, I know it will be cheaper and I can get more stuff.
07-04-2005 05:00 PM
