LT1 & LT4 corvette valve covers
I was looking into the corvette black valve covers and found them new for 100 a piece through GM (but they are plastic?) I was told by the parts man
here are the part numbers can you tell me for sure?
R.H. 12552322
L.H. 12552321
R.H. 12552322
L.H. 12552321
They are a composite cover and they are the GOOD ones. You will have to modify them to get them to work with any other rocker arm than stock. Do a search that will help you find how to do that.
P.S. If you look at my link in my sig you will see a set of then, inow have a SS dress up kit on them.
I had the worst luck with the gaskets on the valve covers. Every time I pulled them off, the gasket would expand by like 3-4 inches. I ended up having to cut them down and attach them with RTV into the groove in the valve cover.
I have bad luck with simple things.
a good trick to stop that is to "glue" the gasket into the valve cover with some weather stripping adheasive
That happened to me and I really thought I was halucinating. I mean one minute they fit to size and the next they were obnoxiously long. I was able to place them back in the slots, but I have a feeling they are leaking on the rear corners. Not sure if they are the right size before applied and stretch with heat?
