lt1 misses at 5500 rpm
im assuming its just in need of a tune up ( 180k miles) but id like to get another 500 or so rpms out of it. what do you think id need: plugs, wires, what else do you think? the airfilter is a new kn so thats good. any ideas?
Mine used to miss @ 4500 rpm,until I changed the coil wire,worth a try
I think the stock rev limit is set @ 5850 rpm,but I could be wrong.
it seems like my engine is pulling its hardest right as it starts to miss. my friend shifts all the way at 6300 on a stock motor. i do think it may be a little un necisary but it dosent feel like power is dropping off. i think i could gain a tenth or so by getting about 500 more rpms out of it.
hey you know i was wondering that for myself, as my car seems to rev too high on the highway,i was worried it was a slipping clutch but i think your right, and yea like i said the stock rev limiter is at least 63-6400
im not really sure other then that it seems like my car pulls the hardest at around the point which it breaks up at and id like to spin it a little higher in search of a little more. the motors coming out in winter anyway so extra wear isint all that much of a concern
sleeperZ96BT
06-05-2005 09:33 PM
Camaro90RS
07-23-2002 07:57 AM
