LT1 Nitrous question
Ok well im new to the nitrous thing but was looking into spraying my bolt on LT1 car. I was looking for recomendations on what system to go with, resons why, and places to get it from. Also I know i can just buy a kit and throw it on and that i will also need cooler plugs, window switch, fuel presssure switch, wot switch, and an msd ignition box for the rev limiter. My question is which ignition box, what plugs, and where to purchase the other things from. Finally what guages should i run with the nitrous install. I was thinking bottle pressure and fuel pressure but are these two good to run and is there another i should use also?
Re: LT1 Nitrous question
the nitrous people on here have lots of good products and all know their stuff, but im gonna throw this out anyways. www.dynotunenitrous.com. they have a ton of stuff. the LT1 wet kit is very good and its about as cheap as you can get new. i would recommend the BMN window swithc, it has a first gear lockouts and it is fully adjustable without pills. im not sure about the plugs, and i would say if you have the window switch and safety stuff you dont need to worry about the ignition box. set the window switch to about 5,800, shift between then and 6,200 and youll be fine. isnt stock limiter at 6,200? anyways talk to the nitrous gurus they know everything.
formula218
12-02-2014 04:27 PM
