Lt1 no start help me!!?!?
Old 05-15-2013 | 04:51 PM
  #16
ugod02010's Avatar
Re: Lt1 no start help me!!?!?
My batt. Was too dead to try so I reaaly only got to check for no1 and 3
No. 1 seemed to rotate probably like 4-6 full rotations of the harmonic balancer between sparks. No3 seemed to be a whole lot closer toger about ever spin or two. Then the battery died. I have a timing light I put on it I really only have pulled the wire off no1 and put the spark tester from autozone on it but I have a really strong spark. Jumps easily about 30 on it( around a inch inch and 1/4
Old 05-15-2013 | 07:49 PM
  #17
ACE1252's Avatar
This is for a 1996 Z28, but most of it should apply for the '95(any DTC references may be wrong...as it's OBDII). It may help out on what is wrong.
http://www.ace1252.com/1996_Z28_Fact...ut_no_run1.JPG
http://www.ace1252.com/1996_Z28_Fact...ut_no_run2.JPG
http://www.ace1252.com/1996_Z28_Fact...ut_no_run3.JPG
It does sound like there is some kind of timing/opti issue.
Old 05-15-2013 | 08:39 PM
  #18
bw_hunter's Avatar
Sounds like a rotor problem to me....maybe pull the cover off the opti and see if it's still intact.
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
InfernalVortex
01-17-2015 09:35 AM
07-04-2005 05:00 PM
1LEThumper
07-14-2003 12:45 PM
Quick Reply: Lt1 no start help me!!?!?
