LT1 Piston Ring Size? mm?
Re: LT1 Piston Ring Size? mm?
As taken from "How to Rebuild LT1/4 Small Block Chevy Engines"
"Production piston rings are low tension rings. Top compression rings are measured at 0.076" thick. Second rings are measured at 0.057" thick. Oil ring packages are measured at 0.165" thick. The GM standard ring set is P/N 12528817. +.005" oversize is P/N 12528818. +.030" oversize set is P/N 12528819."
Hope that helps.
Hope that helps.
10-31-2016 11:09 AM
bossco
11-29-2014 10:18 AM
