LT1 R&R engine guide
Re: LT1 R&R engine guide
You don't need a lift. You must have an engine hoist to pull it out the top, right? The same hoist can be used to lift the car up to take it out the bottom. I took mine out the bottom with nothing more than a floor jack and some creativity.
Originally Posted by blazzinbird
I still would like to know what type of creativity you used rob, cause i dont have a cherry picker, im going to have to borror one
When I started, I had driven the car up on my ramps. With the k-member and shock tower bolts out, I jacked under the member to be able to remove the ramps under the wheels. After placing jack stands on the body behind the front wheels, I could lower the engine and k-member to the ground. I then proceeded to raise the body up as previously mentioned. The engine and k-member assy stayed on the ground as the body went up enough to roll the assy (with wheels on it) out from under. (you will need a dolly, roller skate , etc. under the tranny-or since you are not using the floor jack now, you can use it under the tranny).
Thats kind of what i was thinking rob, ill try to get a picker, i fi cant ill prob do so mething like you did, and be very careful of course
Im wanting to roll the whole assy out with wheels still on
F'n1996Z28SS
08-23-2023 11:19 PM
oldschool
02-09-2016 09:21 PM
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
