LT1 Swap...C230, C220 PIN questions
Hey I am just finishing rewiring a 97 Harness into my 87 Iroc. Now I am left with 3 wires to hook up and need to know what to do to them.
C220 (white connector)
PIN
G------Dk Green/White---Vehicle speed sensor- ( Is this just for the gauge?)
J------Dk Green/White----Fuel pump relay control-(not sure where this goes on a relay)
C230 (blue connector)
PIN
K-----Purple----Output Field Servie enable. (not sure what this does...i tracked it to the DATA plug BUT I am OBD1 now)
Small 3 wire pin (brown,grey,blue)
Brown-deleted
Grey--Deleted
Blue---Fuel enable signal (where would this be wired to?) I copied my old harness and I have a VAT1 box on it. is this for theft so it shuts off the fuel pump?
Jay
PIN
PIN
Brown-deleted
Grey--Deleted
Jay
PIN
G------Dk Green/White---Vehicle speed sensor- yes for the gauge
J------Dk Green/White----Fuel pump relay control not sure what relay you are using but it is a 12v trigger to the relay from the pcm
PIN
K-----Purple----Output Field Servie enable. it goes to the data link connector pin B on OBDI connector
Brown-deleted
Grey--Deleted
Blue---Fuel enable signal (where would this be wired to?) I copied my old harness and I have a VAT1 box on it. is this for theft so it shuts off the fuel pump?Yes so the injectors won't fire
PIN
PIN
Brown-deleted
Grey--Deleted
oldschool
02-09-2016 09:21 PM
Hurin
12-13-2014 07:38 PM
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
07-04-2005 05:00 PM
