lt1 throttle response
125-shot of nitrous, a 6# blower, or an STS rear mount turbo. All can be installed on a stock block LT1 in decent condition.
Or for a more aggressive setup, something like this:
http://www.injuneer.com/images/Video...eBax%20876.WMV
Might help if Sick95Z28 tells us what his budget it. A minimum nitrous setup, with all the safety devices will set him back as much as $1,000.... the S/C or turbo will cost 3X to 4X that amount. Then add in the cost of upgrading the drivetrain and suspension, and it gets expensive.
The 8-second "aggressive" setup might be more like $30-50K, when all the costs are included.
Some preventive maintenance will go a long way in helping you get better throttle response.First make sure air filter is clean,better yet get a lifetime one.Next spray some wd-40/or similiar on the throttle linkage,and then finally spray throttle body cleaner on the butterflies of t/b.This might even result in better mileage as your not using as much throttle to achieve speed,also improved drivability
07-04-2005 05:00 PM
