LT1 timing chain concerns,
I was looking at a timing chain gif that Shoebox posted last week and I noticed at #1 @ TDC the timing marks were at 12oclock on both the cam and crank sporckets.
I had #1 cylinder at TDC and installed the timing set with the timing mark on the cam sprocket at 6oclock and the crank sprocket at 12oclock, just like you would do on a normal SBC.
Am I going to have to yank the chain off and re-do it? The oil pan gasket is a pain in the *** to put back on (motor is in the car).
Re: LT1 timing chain concerns,
You're good to go man! Just to make sure I'm thinking about this correctly the dot on the cam gear is at the bottom and the one on the crank gear is at the top
Is this the diagram you are referring too?
Timing Gears
Richard
Timing Gears
Richard
cool, thanks.
The animated gif showed the timing set rotating and showed where the marks were for tdc of each cylinder.
This is the gif I saw,
That's because the cam turns 1/2 the speed of the crankshaft.
Therefore, the cam mark will be at 12 o'clock at one point and 6 o'clock one crankshaft revolution later. As the crank turns, they align, they don't align, they align, they don't align...
