LT1 Trans temp gauge
Is it very difficult to install a trans temp gauge? My car is in the shop getting the tranny rebuilt and a hayden cooler put in, and when i get it out on monday i want to put a trans temp gauge in.
Re: LT1 Trans temp gauge
VERY easy to install. On the driver side of the transmission is a small access port. Simply remove the plug and screw the sender from the tranny temp gauge in. Run the wire up and over trans. I put mine in wire loom to protect it. Keep it away from the cat and exhaust. Then run wire thru the hole under the PCM and to the sender.I have a A pillar gauge set up.
Rich_z28
08-29-2002 10:44 PM
