lt1 value adjusment pro mags 1.52
lt1 value adjusment pro mags 1.52. I try to do it when the engine runnnig it seems to me it alot harder then other say. Im gonig to do it when the engine cold. How do i do this, i follow the fireing order. Now when the exhaust and intake it down i tighten them until there no lash.I don't now if i should do 3/4 of a turn or 1/2 of a turn. Can some tell me the fireing order just to make sure im good to.
That is the method comp recommended on their install sheet. I went 1/2 turn preload on mine, then torqued the polylock allen to 30 lb/ft, while holding the polylock with a wrench. So far, so good.
I got my torque spec from this thread....
https://www.camaroz28.com/forums/sho...ck+torque+spec
I also adjusted for zero lash per this thread here.....worked perfect....
https://www.camaroz28.com/forums/sho...d.php?t=624416
Caps94ZODG
15
08-10-2002 07:12 PM
