LT1 Water Pump
I agree with the relay kit..you need one, I remember there use to be a guy who would sell them with a warning light and buzzer in-case the water pump gave out. Don't know if they still sell these.
Ok well I got it all back together. I have a relay and a fuse in line to protect the pump. I got all the wiring done and the pump runs. I ran into a problem when filling back up the system though. There is a small hole on the very bottom of the pump housing and water runs straight through it. I welded a plate over the pinion opening of the old pump but how do I fix this one. I was thinking of some permatex and a small screw?
10-31-2016 11:09 AM
