Lt4??
#17
Yes the lt4 does come with a 4 bolt main and you can get a brand new lt4 minus intake from here: http://paceperformance.com/index.asp...D&ProdID=43322
The hardest parts is to find the damn intake
#18
Do you got any part number,because if the engine is from GM it should normally have a GM part number
#21
Yes i already know that.This part number is for a lt4 crate engine 330hp/340tq.I ve bought one this week
But is friend is supposed to have some lt4 long block from GM with over 400hp .Since i never saw gm produce a 400+hp lt4 long block i ask him if he got a part number for this engine.
#22
If you look at other GM Performance Parts and GM Goodwrench websites, it indicate the 125xxxxx part number has been supeceded with an 88xxxx part number. I suspect that means whateverr you are buying is a "remanufactured" engine. I searched everywhere for an LT1 4-bolt main block in 1999, and they were no longer being manufactured. A few years ago, a GM dealer in Denver (Burt Chevrolet) found a supply of OEM 4-bolt main "marine" engines, and that is the last I heard of a factory engine being available.
#23
sleeperZ96BT
09-09-2015 08:28 AM
